02 sonoma p0300, any suggestions ?
Discussion in 'GM Powertrain' started by BLOWOUT, Dec 3, 2012.
  1. BLOWOUT
    BLOWOUT New Member
    Hello all,
    I have a 2002 GMC Sonoma that is throwing a p0300 and i have literally done everything that I could think of or that has been recommended by others. Its cylinders 1&4 that are misfiring. I took it to the dealership and they said it needed to be rebuilt because of a low end knock. Well i had it rebuilt and it is still doing the same thing. Any suggestions would be greatly appreciated! here is what i have done so far
    - Spider injector replaced
    - Distributor, cap, button
    - plugs and wires
    -Ignition control Module
    - Ignition Coil
    - Crankshaft postion Sensor
    - Cleaned MAF
    - Upper intake gasket set
    I am so lost and have so much in it now that i can't just quit on it, thanks in advance for any help!! have a blessed day
  2. RayVoy
    You had the engine torn down and completely rebuilt?????
    Is this on top of the rebuild, or is this what has been done? Sorry, your statements are a little contradictory.
  3. BLOWOUT
    BLOWOUT New Member
    Yes sorry about that all of that on top of a rebuild.
  4. RayVoy
    Wow, ok, that should eliminate a low compression problem.
    I4 engine, or the V6
    Is it possible, the problem has been fixed and not cleared from the PCM.
    A P0300 is a random mis-fire, how do you know it's 1 and 4?
  5. BLOWOUT
    BLOWOUT New Member
    Its the V-6 , and my friend has an OBD II scanner that displays all your engine data and also has a misfire counter. The SES light flashes when at cruising speeds.
