03 chassis ground location?
Discussion in 'Chevy Suburban Forum (GMC Yukon XL)' started by SoundZman, Nov 3, 2009.
  1. SoundZman
    SoundZman Rockstar 100 Posts
    Can anyone tell me where the chassis ground wire is mounted at? I have tried to trace once while working on other things, but couldn't really tell where it went.
    I'm have some alternator issue and thinking it may be related to a corroded ground wire. So I want to go ahead and replace and clean up contact points.
  2. tbplus10
    You dont necessarily need to use the old grounds when replacing them.
    Just run new wires from the Battery to a close spot on the frame, spare bolt on the engine block, and convenient point on the body (preferably the Firewall as it has thicker steel and works better).
    Run a new ground from the body to the frame and body to the engine also.
  3. SoundZman
    Thanks for the tip, I was thinking about doing that as I started earlier today. I was able to replace the battery negative to block and wire brush the terminals on bat neg to chassis. For anyone else interested, the wire runs from the battery down to the frame just behind the driverside fog light. I might take your advice and relocated the firewall braided steel ground strap as I can't possible get to the other mounting location deep behind the block somewhere. I think I will just take it from the firewall stud to the battery or alternator bolt, I'll kick the idea around for a bit. At this point I don't know if replacing and cleaning contact points has taken care of my problem, it will take a couple of day to verify. Thanks!
  4. unplugged
    Never enough grounds
    ditto! I'm a firm believer in adding chassis grounds. Engine to frame, body to frame. I like to put a body to frame ground at both the front and rear of the vehicle.
    I had a buddy who had an earl schieb $99 paint job. Afterwards the speedo cable kept failing. The added paint had reduced the engine/chassis ground. The engine was grounding through the speedo cable. He added four ground straps and a fresh speedo cable and the problem was gone.
