'03 Silverado, cigarette lighter stopped working
Discussion in 'Audio, Video & Gadget Tech' started by gtilley45, Feb 3, 2009.
  1. gtilley45
    gtilley45 New Member
    :sign0144: I have already done a search on every key word I can think of for this, but can't find what I'm looking for. I'm a moderator on another forum so I know how annoying it is for someone to ask a question that has been asked a thousand times.
    But anyway, the cigarette lighter stopped working. I have a Garmin GPS that I use a lot, and I've also got phone chargers, and a thing to play my iPod through the radio that I need to get power to sometimes, so I need both the accessory outlet and the cigarette lighter to work. I have checked the fuse on the drivers side of the dash, as well as the one under the hood. Or at least the fuses that I thought were the right ones. Is there anything else I need to check? Could the cigarette lighter itself be bad? I even pulled the center piece out of the console to make sure they wires hadn't come loose, and they are still connected.
    Thanks for any help!!
  2. MWright936
    Hmm...you checked everything I would have suggested. The only other thing I can think of is the plug itself has gone bad. Maybe someone else will have some other suggestions.
  3. gtilley45
    I thought I had found it today on my lunch break. I was double checking all the fuses, and the 2 green 20 amp ones were good, but then I saw a blue 15 amp fuse that was for the lighter that I'd never seen before. So I pulled it and it was shot. I thought "Well good, that's the problem." So I put a new fuse in and the lighter still doesn't work, so I'm right back to where I was.
  4. Springthing
    Re-check that fuse if you haven't already! Might be blown again, suggesting a short somewhere along down the line!
    I'd get to work with a voltmeter. Check fuses (may as well check all the fuses while you're there.. takes about 5 minutes to check them all with the little plastic fuse puller they give you. Same for under the hood. Once you've sure everything is ok with the fuses, I'd grab the voltmeter and check the wiring behind the panel you had off that power the cigarette lighters. Most voltmeters have sharp leads for a reason... reason is for situations like this. :) Just (CAREFULLY) poke the leads through the insulation and test the wires with the truck in at least the acc. position.
    That's about all I can suggest. If you've got no power at the wires.. then it would be a matter of either checking the wiring all along the route, if you can follow it (most likely will NOT be able to).
    *IF* you have no power and can't figure out what the heck is going on, I would, personally, just save myself the hassle and run a fresh power wire to the outlets. Can even put in a small rocker switch on your dash somewhere if you'd like so you can flip the outlets on/off. (switch and then through a relay, please!)
    Hope that helps a little!
  5. gtilley45
    Well, I feel like an idiot. :slap:
    We got to checking with a test light, and found the problem. We checked all the fuses, and all of them were good. Checked the plug itself, and it still wouldn't work. So I pulled the center piece out of the console and the wire was just dangling. My brother said "You dumb ass, there's what's wrong with it." I told him that I was SURE it wasn't dangling the other day when I looked. So he stuck the test light to the end of the plug, and it lit up. So we plugged the wires back up to the lighter, and it works again.
    I felt so dumb and embarassed. But I KNOW that the wires were connected the other day when I first looked. I guess the plug connector was loose and wasn't making contact or something. But anyway, I just wanted to let ya'll know what the problem was and say thanks for the help. So thanks again, I really appreciate it!
  6. Springthing
    Another problem solved! Good detective work!
  7. daddytech
    you might try checking the fuse block under the hood also , typically up near the firewall on the drivers side
  8. MWright936
    lol, happens to the best of us! Glad you found the problem!
  9. Tater
    Tater Member
    Well that was something i never thought to try so dont feel bad... I also have an '03 silverado with the cig lighter not working. did the fuse check also and they just said screw it, i dont smoke anyhow, and really just use it to charge my spot light during hunting season. now i reckon i should check what you found hu?? thanks for doin the leg work for me!
  10. daddytech
    there used to be a time that GM actually installed those things in a manner that they didn't just randomly come lose like that. in fact I've had some vehicles that you almost had to break the plug to get it off of the back of the lighter assembly. guess that's not so much of an issue any more. now you gotta hot glue them on or something from the sounds of it.
