03 Silverado voltage guage
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by nbturbo, Feb 7, 2011.
  1. nbturbo
    nbturbo New Member
    The other day my gauge was showing 19 volts so I checked it at the battery with my volt meter and it was putting out 13.5 or so volts, i.e., normal. The next day the needle on my gauge was all the way to the bottom, clockwise, and fluctuated a bit at that location. It seems like the needle has over-rotated. When I shut the key off it goes back counterclockwise a bit. Comments? Can I replace?
    thanks
  2. 99'HEARTBEAT
    The Problem is most likely with the Stepper Motor for the Volt Gauge is Going Out/Bad........and needs to be Replaced with a New Stepper Motor........it is a Common Problem on the 2003" to 2005" Trucks/SUV's Dash cluster's.
  3. nbturbo
    nbturbo New Member
    Thanks very much; Is there a DIY for this anywhere?
    ---------- Post added at 01:33 PM ---------- Previous post was at 01:13 PM ----------
    Never mind, I found your diy 99 heartbeat; thanks for this.
    d
  4. 99'HEARTBEAT
    I Assume you found the Thread on Replacing the Stepper Motor's.....:glasses:
  5. nbturbo
    nbturbo New Member
    Yes I did, thank you heartbeat
    d
