04" GMC Envoy SUV---Towing A Boat
Discussion in 'Towing & Trailer Tech' started by bighammer, Jun 26, 2014.
  1. bighammer
    bighammer New Member
    I HAVE A 2004 GMC ENVOY XUV WITH ON LY 42KKK ON IT BOUGHT FROM A WIDOW THEY BOUGHT IT BRAND NEW, MY ? IS IT DOES NOT HAVE TOW AND HAUL ON IT, DO I JUST PUT IT IN REGULAR DRIVE OR #3 ON THE DASH ? ANY HELP WILL BE APPRECIATED THANKS BIGH:glasses:
  2. kennythewelder
    kennythewelder Rockstar 2 Years 1000 Posts
    The transmission will automatically select the correct gear. You can just use it in 4th.or O.D. before they had a tow hall button that's all you could do. My 1997 Silverado 5.7L has no tow hall button and I use to pull my bass boat just fine no problem. Welcome to the forum
  3. 99'HEARTBEAT
    We need just a little more Information on this 04" GMC Envoy, Do you know what Size Engine-n-Rear Gears it has??......it most Likely has the 4L60E 4-Speed Auto Transmission....and "D" is Over-Drive"......Depending on What Rear Gears this Vehicle has and the Weight of the Boat your going to be Towing.....3rd Gear would be the Better Choice....but this All Depends on
    the Weight of the Boat and the Engine-n-Gears the Vehicle has??.....also if it has the Factory Tow Package.
    To find out what Gears your Vehicle has,....Inside your Glove Box is a White Tag/Sticker....which is the Service Parts I.D. Tag(Pictured Below)and on it you will see your Vehicles Vin # Number and a Series of Letter's and Number's which are RPO Codes.....which stands for Regular Production Options...In Short what that Vehicle came with from the Factory, you will be look for one of the Following RPO Codes.
    GU4 -- AXLE REAR, 3.08 RATIO
    GU5 -- AXLE REAR, 3.23 RATIO
    GU6 -- AXLE REAR, 3.42 RATIO
    GT4 -- AXLE REAR, 3.73 RATIO
    GT5 -- AXLE REAR, 4.10 RATIO
    G80 -- LOCKER
    Here's the Service Parts Identification Label
    [​IMG]
    The RPO Code for the Factory Tow Package is....Z82.....TOW/TRAILER EQUIPMENT, HD.....it Includes Trailer Hitch Platform. 7 Wire Harness, K47 High Capacity Air Cleaner, (KNP) Cooling External Transmission Cooler.
  4. bighammer
    thanks
    thanks kenny the welder for the information it was helpfull thanks again:glasses::glasses:
  5. kennythewelder
    Sure, your welcome
  6. bighammer
    i just returned from vaction and the info i was given in this site was very helpfull everything worked fine driving in overdrive but gas milage not so good averaged 15 and halve mpg, but i have another ? where can i find an owners manuel , because we found out the roof will retract and i understand they on ly made 12000 of these models any help will be greatly appreciated, you guys have been very helpfull already thanks bigh
  7. XANDERCONNIE
    XANDERCONNIE New Member GMTC Chick
    I have a 2004 GMC Envoy that I bought new. She has 212,000 miles and is still going strong. You do have a roll back roof but you have to roll down the back window before the roof will activate. Also, you can roll down the divider window and fold down your seats for more cargo room. I have my original owners manual if you would like a copy. I'm sure there are sites out there where you can get one though.
    Beware of the back window... we had a family member slam the tailgate door last summer after launching our boat and the window wouldn't go back in place. (It automatically lowers a small bit every time you swing the back gate open.) We had to have the regulator replaced on the back window to repair it. We had the middle cargo window regulator replaced when the car was about 5 years old. This is an apparent flaw with the vehicle because our middle cargo regulator needs to be replaced again.
