04 gmc rear brake caliper brackets
Discussion in 'General Chevy & GM Tech Questions' started by dave13net, Sep 17, 2013.
  1. dave13net
    dave13net Rockstar
    i have a 2004 gmc 1500 sierra 4wd, need to replace rear brake rotors and pads and rusted out backing plates. tried to get caliper brackets off but would not budge, was told to use heat on bracket (didn't try yet) waiting for weekend so not to tie vehicle up . can't seem to get the bolts loose,afraid to much pressure will break them off. can't get impact gun in there either. any help would be appreciated, DUE NEXT MONTH FOR INSPECTION
    thanks,dave
  2. dsfloyd
    penetrating oil, heat and breaker bar. I think on my truck the bracket torque spec is over 225 ft-lbs. Not as high on a 1500 but I remember fighting the bolts initially. Also arent they torqx heads, so make sure you have a quality one as I have had a few cheap sockets twist easily.
  3. dave13net
    dave13net Rockstar
    the bolts are 17mm and i did try penetrating oil, but not any good spots to actually get it in there. threads go in behind rotor itself. thanks for the info
  4. Pikey
    I have never had to heat them and I have done probably 15 or 20 of them. I just use a 1/2" breaker bar that is 2 ft long, then I slide a long 4 or 5 foot pipe over the end. Yea, there is not much room for the pipe. I usually have to jack the truck up high enough that I can get some room between the ground and the body of the truck. Luckily, I have never broken one either.
  5. dave13net
    dave13net Rockstar
    ok thanks for the info, just hope i don't break them either, don't need that problem too
  6. Pikey
    As far as the backing plates go. If you want to do oem replacements then you have to pull the axle shafts. I have seen people use the aftermarket 2 piece plates and they work well. You would just need to cut the old plates off and then bolt the new 2 piece on.
  7. dave13net
    dave13net Rockstar
    ok thanks, thought i would have to pull axles anyway,just more work. where would i get the 2 piece if i wanted to go that way?
  8. Pikey
    I think that advance, autozone, and napa all carry them
  9. zippstripp
    zippstripp Member 1 Year
    Those bolts can be a bear. Heat won't hurt the bolt. Not to mention the factory also uses a thread locker on them so heat would help loosen that up.
  10. dave13net
    dave13net Rockstar
    ok. thanks
