04 rearend in a 96 sub will it work?
Discussion in 'GM Powertrain' started by pkbell, Sep 8, 2010.
  1. pkbell
    pkbell New Member
    I have a chance to pickup a 2004 1/2 ton rear end with 373 gears and disk brakes. I have a 1996 sub 1500 with 373's and drum brakes and a bad pinion gear. Both a 10 bolt. Will this setup adapt to the 96?
    with minor changes to the system ..i would say yes !!!! as long as the abs adobs it and also the springs and shoks are at the same location !!!
    WHY NOT, would be easyer to change the brakes over and fix your gear..but thats just me..lol
  3. murdog94
    Make sure you check the spring perches any be sure they are in the same location and measure the distance as well.
