'04 Silverado LS Odometer Error Message
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by leroy.jr1025, Jan 20, 2014.
  1. leroy.jr1025
    leroy.jr1025 New Member
    I have been receiving an odometer error message for quite some time now and I was looking for suggestions on where to look for a replacement digital cluster. Anyone know whether I will be able to retrieve the miles off the old one? It is for a 2004 Silverado LS EXT Cab 5.3L. Thanks
  2. Jamm3r
    gaugeguys.com - They're local for me and have a great reputation. They will rebuild your existing cluster. I believe miles are actually in the pcm so changing the cluster won't affect them.
  3. j cat
    have the dash cluster repair people set the correct mileage. you want the PCM and the dash cluster to be the same !
  4. redvett
    redvett Rockstar 100 Posts
    Only the cluster keeps the mileage PCM & BCM do not.
  5. j cat
    I have been told the PCM records the mileage as well as the dash cluster. if they check this and find the mileage is different then this is under federal laws about mileage tampering.
  6. 99'HEARTBEAT
    This Bulletin from GM, expresses how to change the mileage and where it is stored on all their vehicles. It will be in the (IPC) Instrument Panel Cluster or the Integrated Body Control Module (IBCM) also commonly called a Body Control Module (BCM)
    Tool Tip Element
    Service Information
    Document ID: 2141327
    #07-08-49-020B:
    IPC Odometer Programming Method Quick Reference Guide - (May 22, 2008)
    Subject:
    Models: 2003-2009 GM Passenger Cars and Trucks (Including Saturn)
    2003-2009 HUMMER H2, H3
    2005-2009 Saab 9-7X
    Attention: This bulletin applies to vehicles sold in the U.S. and Canada Only.
    This bulletin is being revised to add information for the 2009 model year and add new 2009 vehicles. Please discard Corporate Bulletin Number 07-08-49-020A (Section 08 -- Body & Accessories).
    The purpose of this bulletin is to provide a reference guide to help identify which Season Odometer Programming Method to use after replacing the Instrument Panel Cluster (IPC).
    The Three Season Odometer Programming Methods in use today are listed below. In Addition, this Reference Guide lists the Component where the Season Odometer Value is Stored.
    The Season Odometer Value may be Stored in the IPC, the Driver Information Center (DIC), or the Integrated Body Control Module (IBCM), also commonly called a Body Control Module (BCM).
    Season Odometer Programming Methods In Use Today,
    IPC Reprogramming and setup using the Service Programming System (SPS).
    Odometer setup at the Electronic Service Center (ESC) when using an exchange IPC/DIC.
    Tech2® -- The Tech2 is used to setup a replacement BCM, which includes loading the Odometer Value that is Displayed and Stored in the IPC. A replacement IPC will display the previously Stored Vehicle Odometer Value, communicated from the BCM, after cycling the ignition or driving the vehicle.
    Model
    Model Year
    Odometer Value Storage
    Buick
    Century
    2003-2005
    IPC
    ESC
    Enclave
    2008-2009
    IPC
    ESC
    LaCrosse/Allure
    2005-2009
    IPC
    ESC
    Lucerne
    2006-2009
    IPC
    ESC
    LeSabre
    2003-2005
    IPC
    ESC
    Park Avenue
    2003-2005
    IPC
    ESC
    Rainier
    2004-2007
    IPC
    SPS
    Regal
    2003-2004
    IPC
    ESC
    Rendezvous
    2003-2007
    IPC
    ESC
    Terraza
    2005-2009
    IPC
    ESC
    Cadillac
    CTS
    2003-2009
    IPC
    ESC
    DeVille
    2003-2005
    IPC
    ESC
    DTS
    2006-2009
    IPC
    ESC
    Escalade
    2003-2006
    IPC
    SPS
    2007-2008
    IPC
    ESC
    Seville
    2003-2004
    IPC
    ESC
    SRX
    2004-2009
    IPC
    ESC
    STS
    2005-2009
    IPC
    ESC
    XLR
    2004-2009
    IPC
    ESC
    Chevrolet
    Astro
    2003-2005
    IPC
    ESC
    Avalanche
    2003-2006
    IPC
    SPS
    2007-2008
    IPC
    ESC
    Aveo
    2004-2009
    IPC
    ESC
    Blazer
    2003-2005
    IPC
    ESC
    Colorado
    2004-2009
    IBCM
    Tech 2
    Cavalier
    2003-2005
    IBCM
    Tech 2
    Cobalt
    2005-2009
    IBCM
    Tech 2
    Corvette
    2003-2009
    IPC
    ESC
    Epica
    2004-2006
    IPC
    ESC
    Equinox
    2005-2006
    IBCM
    Tech 2
    2007-2009
    IPC
    ESC
    Express
    2003-2009
    IPC
    ESC
    HHR
    2006-2009
    IBCM
    Tech 2
    Impala
    2003-2009
    IPC
    ESC
    Kodiak
    2003-2009
    IPC
    ESC
    Malibu
    2003
    IPC
    ESC
    Malibu
    2004-2009
    IBCM
    Tech 2
    Monte Carlo
    2003-2007
    IPC
    ESC
    Optra
    2004-2007
    IPC
    ESC
    S-10
    2003-2004
    IPC
    ESC
    Silverado Classic
    2003-2007
    IPC
    SPS
    Silverado
    2007-2009
    IPC
    ESC
    SSR
    2003-2006
    IPC
    ESC
    Suburban
    2003-2006
    IPC
    SPS
    2007-2009
    IPC
    ESC
    Tahoe
    2003-2006
    IPC
    SPS
    2007-2009
    IPC
    ESC
    TrailBlazer
    2003-2008
    IPC
    SPS
    Traverse
    2009
    IPC
    ESC
    Uplander
    2005-2009
    IPC
    ESC
    Venture
    2003-2005
    IPC
    ESC
    GMC
    Acadia
    2007-2009
    IPC
    ESC
    Canyon
    2004-2009
    IBCM
    Tech 2
    Envoy
    2003-2009
    IPC
    SPS
    Jimmy
    2003-2005
    IPC
    ESC
    Safari
    2003-2005
    IPC
    ESC
    Savana
    2003-2009
    IPC
    ESC
    Sierra Classic
    2003-2007
    IPC
    SPS
    Sierra
    2007-2009
    IPC
    ESC
    Sonoma
    2003-2004
    IPC
    ESC
    TopKick
    2003-2009
    IPC
    ESC
    Yukon
    2003-2006
    IPC
    SPS
    2007-2009
    IPC
    ESC
    HUMMER
    H2
    2003-2007
    IPC
    SPS
    2008-2009
    IPC
    ESC
    H3
    2006-2009
    IBCM
    Tech2
    Oldsmobile
    Alero
    2003-2004
    IPC
    ESC
    Bravada
    2003-2004
    IPC
    SPS
    Silhouette
    2003-2004
    IPC
    ESC
  7. j cat
    with your info on this being stored in the BCM and dash cluster GM made this change back in 2003.
    In my 2000 it is in the PCM and dash cluster ,, from my reading of this. what ever the case it is stored in 2 different places.
  8. 99'HEARTBEAT
    .....On the GM FullSize Trucks, the IPC Stores the Mileage, the BCM will"Keep Record"of the Current Mileage, and
    the BCM reads the IPC.
    The BCM Updates itself. if your Cluster has 128K miles....The BCM sees 128K miles.
    Plug in a Cluster with 52K miles, Fire it up, and Drive around, and the BCM now reads....52K miles.
  9. j cat
    that all makes sense.
