04 tahoe squeaking pulley sound
Discussion in 'General Chevy & GM Tech Questions' started by mike042, Dec 29, 2010.
  1. mike042
    mike042 Member
    hi everyone im haveing trouble finding where noise comeing from. it sounds like a squeaking belt pulley but it only squeaks when its damp or raining. it goes away when motor gets hot. no noise at all if wheather is dry even when truck sits for couple of days as long as its dry air. but a little snow or rain and it comes back on start up?
  2. murdog94
    When was the belt last replaced??? Since a worn belt will do that, as well as the AC belt and tensioner could be worn out.
  3. TexasEdition
    TexasEdition Rockstar 3 Years 500 Posts
    Get a Gatorback belt made by Goodyear. I had the same problem on my 2004 and this fixed it. The regular belts all did that squeeking thing.
  4. mike042
    mike042 Member
    thanks guys the belts about 3 yrs old so ill try the new one hope its just the belt. im in new england 2 feet of snow on ground and no garage dont need a long job outside right now!! ha
  5. stephan
    Since you plan on replacing the belt anyway, when you have the old belt off & before you put the new belt on, start the engine. If the squeak is still there then you know it is in the engine & wasn't the belt/pulleys or any of the the accessories it runs.
