05 1/2 ton chev sub liftgate won't open
Discussion in 'Chevy Suburban Forum (GMC Yukon XL)' started by econn2000, Jun 7, 2008.
  1. econn2000
    econn2000 New Member
    05 1/2 ton suburban liftgate will not unlock or open. All labeled fuses are good, lock/unlock relays work, all other doors work fine, even with fob. Is there a safety interlock? Any manual/emergency method of opening other than drilling?
  2. unplugged
    I don't have any particular experience with your model, but I have two thoughts:
    If the window isn't rolled all the way up, it may have an interlock.
    From the inside, remove panel screws/fastners to access the latch mechanism to open the tailgate so that you can get a closer look at what's malfunctioning.
    Good luck, let us know what you find.
