05 Yukon 4wd problems
Discussion in 'General Chevy & GM Tech Questions' started by wodge1, May 1, 2013.
  1. wodge1
    wodge1 New Member
    The "service 4wd" light stays on and sometimes it shifts itself into 4 low. Any ideas?
  2. Pikey
    I would start with the switch. If you pull it apart you may find some bad solder connections.
  3. donyms
    Welcome to the club, it's great to have you aboard. :glasses:
  4. wodge1
    wodge1 New Member
    thanks and I'll look at the 4wd switch today
  5. mfleetwood
    ****Thread moved here to correct section*****
  6. SurrealOne
    Welcome! :great:
    Any luck?
  7. wodge1
    wodge1 New Member
    I'm finally getting back to the Yukon after just pulling fuses. I got the back of the dash switch off and don't see anything wrong, time to dig deeper
  8. Pikey
    You might need to open the switch and check for bad solder connections INSIDE of it.
  9. wodge1
    wodge1 New Member
    I did that, that's what I meant when I said I got the back of the switch off. Apparently you cant take the circuit board out
  10. wodge1
    wodge1 New Member
    Had the transfer case oil changed and the problem went away till the wife put it in 4auto. The light came back on a while later and it shifted itself to 4low.
