100,000 Mile Maintenance?
Discussion in 'Maintenance & Upkeep' started by Localsun77, Mar 6, 2013.
  1. Localsun77
    Localsun77 New Member
    Hello everyone! I just bought a new to me 2009 gmc sierra and I have about 74 k in it. I was wanting to know everyone's opinion or advice for 100k maintaince, thanks!
  2. 99'HEARTBEAT
    *****Thread Moved*****
    To The
    Maintenance Tech Section
  3. Localsun77
    Hey thanks, nice to meet everybody, hoping to get some pics of my truck up
  4. 99'HEARTBEAT
    Depending on What Maintenance has been done to the Truck at this point "74K miles".......when it hits 100K Miles, you could look at some the following,
    ......A Cleaning of the MAF Sensor.....using CRC's MAF Sensor Cleaner
    ......^^^^^^^^^^^^^^ Throttle Body and Injector's
    .....A Flush of the.....Coolant, Brake, Steering and Diff. Fluids
    .....On the Transmission, Drop the Pan and Replace the Filter
    .....A New Set of Plugs-n-Wires and go with A/C Delco Iridium Tip Spark Plugs
    .....Check All Belts-n-Hoses, and Replace if needed
    .....Check the Brake Pads, Replace if needed
  5. Pikey
    I agree with what [MENTION=25593]99'HEARTBEAT[/MENTION] posted. You may also want to check out the shocks.
  6. KyleZ71
    All the above and I would also look into changing the fuel filter
  7. Pikey
    I don't think that the fuel filters are changeable after 2004. My 05 has a filter in the tank
  8. KyleZ71
    that may be a problem
  9. 99'HEARTBEAT
    Correct.....
    starting in 2004" the Fuel Filter was moved to the Fuel Tank and is non-serviceable, with the exception of the Flex Fuel and the 4.3 V6. They were moved to the Tank in 2005" and now part of the Fuel Pump Assembly.
  10. Pikey
    I would also change the t-case fluid. I think that the recommended interval is 50,000 miles.
