12V amp power supply
Discussion in 'Audio, Video & Gadget Tech' started by Hoyt06, Apr 11, 2010.
  1. Hoyt06
    Hoyt06 Member
    I have an 05 silverado.. Wanting to hook up an amp to aftermarket deck.. My question is I am having a tough time finding a spot on the fire wall that I can run the 12v power supply wire?? I would rather not drill a hole, but would like to find an existing spot to run it through.. This truck is very crowded aginst the fire wall.. Has any one ran a 12v power supply thru their fire wall on a similar truck ,and where did you run it?? Thanks:rofl:
  2. Hoyt06
    Hoyt06 Member
  3. Sandhopper
    Sandhopper Rockstar 100 Posts
    Not sure if there are existing through-hole but there is a very convienet 12 supply on the drivers side of the motor. there is a red box (I think fusable link) that is a great location to grab power. I have pulled power from there for power winches on 4 of my vehicles and never had any problems.
  4. Stealth
    Could you possibly give us a picture Sandhopper?
  5. wis bang
    wis bang Rockstar 100 Posts
    The owners manual for my '05 worktruck calls that a 'remote' point to be used for jumpstarting.
  6. Enkeiavalanche
    You might have to drill a hole above the Steering wheel or pedals Just make sure that you don't interfear with the pedals and use a rubber gromit in the hole..
  7. Hoyt06
    Hoyt06 Member
    yea thats what I figured I would have to do:neutral:
  8. dsfloyd
    On my 04 I have 1 or 2 holes in the driverside firewall. I will see if I can get a pic of the location. Its in the upper left hand corner
  9. dsfloyd
    here is where i have run wires. There are two holes just to the right of the master cylinder. comes through behind the black box to the left of the break pedal.
  10. Hoyt06
    Hoyt06 Member
    thanks for the info.. Ill check it out closer.. I havre already looked there but will look a little closer..:happy:
