1987 surburban electrical issues
Discussion in 'General Chevy & GM Tech Questions' started by roywfields, Jun 15, 2012.
  1. roywfields
    roywfields New Member
    truck has been sitting awhile. it was fine until the other day neede to be jumped but i changed the starter and had alternator checked. now it will not start just turn over and the lights dont work but brake lights come on when pressed. no inside lights. used tester on fuses and nothing would light up.
  2. 08_rado_rocker
    08_rado_rocker Member 2 Years 500 Posts
    First off: Welcome to GMTC!! We're glad to have ya aboard here and there's lots of experience and knowledge
    Issue: Now, were you using a test light and that's what you mean by "nothing would light up" meaning everything in the fuse panel was dead?
  3. roywfields
    yes sir i have checked also for corrosion at battery post just changed starter. It was towed home and i was thinking maybe it was vapor lock or fuel pump but none of that was the cause. i do have hazard and brake lights it will turn over but no fuel is getting to carb, all the fuses was pulled and they all were good.
  4. 08_rado_rocker
    I'm unfamiliar with the fuse block on the vehicle.. but are the wires routed directly into the block, or are there several plug-ins and terminals for them? If so, you may try taking them out and hitting them with some electronic contact cleaning spray (Not an electric parts cleaner or wd-40, as they both conduct electricity and can cause shorts. the contact cleaner dries quickly preventing any shorting, also make sure the battery is unplugged just in case). Also, di-electric grease used in the factory could be causing them to lose connection and should be cleaned out using the contact cleaner.
  5. SurrealOne
    We are the Borg. Lift your vehicle and surrender your keys. We will add your biological and technological distinctiveness to our own. Resistance is futile. Erm, I mean ... welcome to GM Truck Club! :great: It looks like rado has you in capable hands, so good luck with your issue.
  6. mfleetwood
    ****Thread Moved Here*****
    Welcome to the Club!!!
