1989 K2500 Silverado Wiper Issue
Discussion in 'General Chevy & GM Tech Questions' started by Grady, Jun 12, 2011.
  1. Grady
    Grady Member
    I tried the wipers on my truck but nothing happened. I left them on High - bad idea. A minute later smoke from the switch. Now what? Any suggestions? The truck had been sitting for a while except being run around the farm but the wipers hadn't been used for months. I'll check the circuit board but what about the smoke?
  2. csltrains96
    csltrains96 Rockstar 100 Posts
    First - nice to see another '89 K2500. Second - were these dash mounted wiper controls, or turn signal mounted controls?
  3. Revredneck
    Revredneck Rockstar 100 Posts
    Smoke from the switch is not a good thing. The most common problem with the wipers on those trucks is a cracked solder joint on the circuit board in the wiper motor. I've repaired dozens of them with just a soldering iron and touch of solder. Take off the cover of the motor and the board will just pop right out. Inspect it carefully. I'll bet you'll see a burned portion in the printed circuit, which means you'll need a new circuit board and a new switch.
    Good Luck and God Bless
  4. Grady
    Grady Member
    smoke from switch
    Thanks for the replies. My switch is on the turn signal lever and the smoke was very slight, not serious but still not a good sign. Something got hot. I had the steering wheel apart a few years back, maybe 5 or 6 yrs, to change the ignition [key] switch. [I think] like I said, it was years ago and I'm not getting any younger. As I recall it wasn't rocket science but it wasn't like changing the oil either. If I have to change the switch, I may be back for some pointers. As I recall there was some spring I had to compress while trying to do something else at the same time like a snap ring or something. It gave me a chance to practice some colorful language. Since my turn signals don't stay on I could fix that at the same time. I'm still hoping that won't be necessary. I guess I should start with the circuit board and see if the switch works. - or will the switch trash the new board? Who knows? Right?
