1990 Suburban brakes
Discussion in 'General Chevy & GM Tech Questions' started by Knucklehead, Apr 29, 2009.
  1. Knucklehead
    Knucklehead Rockstar 100 Posts
    My Suburban has recently started pulling to the left during braking, well the steering wheel turns , not so much the truck. So my first step was to change the calipers, and the problem is still there. The tires pressure is correct , theres plenty of fuild pumping through the brake lines and the master cylinder seems to be working correctly. Also i noticed it seems like brake dust collects faster than i remember. I dont know if they are related problems , but any suggestions would be helpful!
  2. ct9a
    Make sure that the floating pins are properly lubed and/or not frozen.
  3. corova
    corova New Member
    check your speed sensors
  4. tbplus10
    Check the front brake lines to make sure they arent expanding under pressure, this happens a lot on lifted trucks.
  5. CarpenterGuy
    CarpenterGuy Epic Member 5+ Years 500 Posts
    did you change the rotors with the calipers?
  6. Knucklehead
    Sorry it took so long to get back , yes about a week after i posted and its still the same story , im thinking the brake lines, although there is no visual defects i understand that they can deteriorate from the inside first.
  7. mespe
    mespe New Member
    Well, can you tell us what you found to be the problem?
  8. vncj96
    Just get full steel braided brake lines, better in heavy braking and no expansion of the lines either, they are woth the extra $$. Also even an alignment/tire balance can cure brake pull
  9. mespe
    mespe New Member
    Turns out my left front rubber brake line was expanding, causing the RF brake to pull the truck to the right. What a PITA conencting the LF steel brake line to the proportioning valve,,, should have taken 15 minutes to replace the lines, took me 2 hours and alot of frustration. but the truck brakes straight now. So it's on to the next step WVO conversion.
