1991 chevy 1500 charging problems
Discussion in 'General Chevy & GM Tech Questions' started by bigblue1500, Jan 17, 2010.
  1. bigblue1500
    bigblue1500 New Member
    I have a 1991 chevy 1500 4X4 350. i was driving it and the battery light came on so i checked the voltage and the alternator was not putting out. so later i got back in my truck and started it up and the alternator was charging again. when im driving every once in a while the headlights will get real bright and the battery light will come on as if its charging real high, this happens for a few seconds and returns too normal..... could it be my alternator? does the alternator have an internal voltage regulator???
  2. minigts
    minigts New Member
    Well it's a one wire alternator, correct? If so I would think it has to be internal. I'm working on a 1990 and his setup seems to have a similar problem. The battery and alternator have both been checked and neither are bad. And since it's a pretty simple system, there aren't too many things that can go bad. :) I'm just guessing yours is a one wire alternator though.
  3. timsilverado
    timsilverado New Member
    Yes, it does have a voltage regulator. But the brushes could be going and just hit and miss. Or the stator could have a bad spot.Since you've tested the battery, it's a safe bet you need an alternator. Just be sure to check out all your connections first to make sure there is no corrosion or loose wires/connections.
  4. john k
    john k New Member
    I'm having a similar problem I lose voltage for a few minutes and then it returns to normal. got so bad i had to change the alternator and battery
    and the module went . now the truck runs well I thought I was all set when 2 days later i am losing voltage again . it is driving me nuts because its intermitant
    i added grounds to body,frame motor. if anyone has any ideas i would appreciate it thanks..
  5. stephan
    John, This sounds like a floating ground problem. Check your connections where you put the battery negative to the engine & engine ground to frame. No paint or rust here, it must be clean shiny metal to metal contact. If batt to frame & frame to engine grounds are good & the alternator ground wire you added is also good, then check your engine to body grounds at the firewall.
  6. MightyMax
    MightyMax Rockstar 100 Posts
    I have a 91 350 also.
    Had a similar problem last summer.
    The cicuit itself is pretty simple....
    If you have used a Volt meter and confirmed that voltage is right (when on) at the alternator (~14v),
    Check the voltage back at the battery, and see if you read the same voltage.....my guess is maybe not.
    Then if you also have an ohm meter, check resistance between the two points, alternator and batter terminal.
    Should be little to no resistance.....if there is resistance, then you have a bad wire.
    What fixed my problem, was taking the wiring harness that runs on the passenger side of the engine block and pulling it towards the firewall and putting a zip-tie in place to hold it there. So I probably have a bad wire and just am too lazy to deal with changing it out. :D
