1991 s10 enigine swap to 350
Discussion in 'Chevy S10 Forum (GMC Sonoma)' started by davidrush91, Oct 29, 2013.
  1. davidrush91
    davidrush91 New Member
    OK i'm looking for some good advice here.
    I'm looking to take my 1991 Chevy s10 and swap my 2.8 v6 for a 350. it is a 5speed and im looking to keep it that way when i swap over.
    What i would like to know is, what all do i need to complete this swap and make sure that the truck will run this motor with no problems?
    One big question is what transmission am i looking for to bolt up to the motor? any help would be appreciated.
  2. Bowtied
    Bowtied Epic Member 5+ Years 500 Posts
    Well if you are trying to keep it as close to OEM as possible you may be able to use your transmission on a 350. I noticed from the wiki article about your NV3500 transmission was used in 91-06 silverado's but that may be with the 4.3L v6 not the v8's.
    here's Hamburger's "kit in a box" from jegs which is prob the direction i'd be leaning if i had the crate motor but no accessories. but also be scouring the internet like crazy trying to read other peoples S10 w/ 350 conversion blogs (of which i could find none at the moment) to get as much info on successes/troubles to be foreseen.
    Are you going with a junkyard restoration, crate motor, or?
  3. Enkeiavalanche
  4. davidrush91
    " Im going to try and buy a used 350 and rebuild it"
  5. 95_5spd
    95_5spd Active Member 2 Years 100 Posts
    Basically you wanna change most of the drivetrain stuff. Look up some 5 speed transmissions for 350's like the t-56.
    Here's a little something right here
    http://www.hotrodders.com/forum/s10-5-speed-chevy-350-a-159923.html
    Should get a new rear end too and if you're pushing a good amount of power a strong driveshaft would be worth it. Just beef up all of that stuff and you will be set.
  6. BurbanMan
    I'm pretty sure The 2.8 transmission has a different bolt pattern than that of the 4.3v6 and the v8's as the 2.8 v6 is a 60* and not a 90* engine like the v8. I'm sure a local tranny shop can confirm or even someone else on her
