1993 GMC Sonoma Headlamp and turn signal probs!
Discussion in 'GM Electrical Tech' started by Claire, Sep 10, 2012.
  1. Claire
    Claire New Member
    The left indicator does not work, the arrow stays solid on the instrument panel. The right headlamp doesn't work. The hazard lights work fine, all 4 indicator lights flash when I switch that on, just the marker light on the left front stays off.
    Where do I start?
    TYIA:)
  2. RayVoy
    Separate problems. Change the headlight....................that will give you a boost to fix the signal problem.
    If the right signal works ok, and the left does not do anything, it probably is the signal flasher.
  3. Claire
    Claire New Member
    I think I edited before I saw you'd answered:(
  4. RayVoy
    I think you did, but my answer is the same :)
  5. Claire
    Claire New Member
    I only just got around to it (farm truck), but you were right! It took about 30 seconds to fix it. TYVM:)
