1994 diesel hard start when hot
Discussion in 'GM Diesel & DuraMax' started by BIGDRILL, Mar 15, 2012.
    BIGDRILL New Member
    Father in law has a 94 6.5 that will start everytime when cold. when very hard to start( crank and go dead), then take forever to restart. I have cummins, but need help. Thanks very much.
  2. Dukeschevy
    Dukeschevy Rockstar 100 Posts
    The PMDs (pump mounted driver) usually go bad once overheated, I had to replace mine when it kept stalling. It would run fine until the truck warmed up then it sometimes stalled, ran like crap, or didnt start at all. It could be something completly different but this is common. Hope this helps Good luck
  3. Asphalt Animal
    Asphalt Animal Rockstar 100 Posts
    Most likely PMD matter. When it doesn't start, see if you get any smoke out the tailpipe, or crack an injector line to see it if delivering fuel. If neither, probably the PMD.
  4. Joeairforce
    Hard starting only when the engine is hot is a sign that the head and rotor inside the IP is worn.... Time for a new IP...
