1994 GMC Yukon
Discussion in 'General Chevy & GM Tech Questions' started by 1994 GMC Yukon, Nov 8, 2010.
  1. 1994 GMC Yukon
    1994 GMC Yukon New Member
    Hello, I own a 1994 GMC Yukon 2 door 4wd with the 5.7L V8. It has the W/T trim level if that even exists but it has the square headlights, i was wondering if there is a conversion to the standard stacked style lights 2 - Copy.jpg
  2. 2COR517
    Saw a 99 like that not too long ago. 2 bulb sealed beams, roll 'em up windows, vinyl seat & floor.
    Not positive, but I think you can put any style headlight that came on those from 92-00. I know the rad supports from LMC for example will work with any headlight formation.
  3. murdog94
    Same with the OEM core supports you simply need to get the headlight harness from a donor truck (easy to change and get to) and then your pick of headlights just be sure that they have all the needed brackets/hardware included. And a grill. And you will be good to go.
