1995 Motorhome on P30 Chasis 454 won't stay running
Discussion in 'General Chevy & GM Tech Questions' started by Rascl93, Aug 28, 2012.
  1. Rascl93
    Rascl93 New Member
    I need some help and advice. We have a 1995 Gulfstream Sunvoyager motorhome on a P30 chasis. The engine was torn down when we bought it - long story short, after having heads redone, new piston, new valves, new lifters & rods, we have the engine back together. We have replaced both temp sensors in the heads (driver's & passenger's side), checked for vacuum leaks, new fuel pump, new cap & rotor, and still have a problem.
    It will start and run for a few seconds then shut down. If you can catch it before it shuts down and feather the throttle, you can keep it running, but not good. It will not hold a steady RPM.
    Suggestions please.
    Thanks.
  2. Rascl93
    Rascl93 New Member
    Forgot to mention - it's only got a little over 20,000 miles on it. Bank repo + trash through the throttle body = trashed piston.
  3. RayVoy
    It sounds like a classic fuel delivery problem.
    Pump, filter, or throttle body.
    With the info provided, I'd lean toward the throttle body.
  4. Skippy
    Skippy Member 2 Years 100 Posts
    Double check your wiring order. I've seen a lot of rough running engines with a single wire swapped at the cap.
    -Skippy.
  5. Rascl93
    Rascl93 New Member
    It will start, but then it shuts down. Almost like something is telling it to shut down. Wondering if we have a fuel pressure issue.
  6. RayVoy
    Perhaps, this was my answer in post #3
  7. Skippy
    Is this a carburetor , TBI, or electronic injection fuel delivery system?
  8. Rascl93
    Rascl93 New Member
    TBI - and yes RayVoy, your post is what leaned me in that direction. No need to get snotty about it. :tongue: If you would have read my original post thoroughly you probably would not have mentioned fuel pump since I stated that it is new.
    Anyway, it is getting fuel to start. Just not sure where to go from here. Should I rebuild the throttle body or check in to the computer.
    Thanks everyone for your input.
  9. RayVoy
    Sorry Rascl, that was not my intent, just wanted you to reread my first post.
    I saw that you had installed a new fuel pump, I was just saying your description sounded like the classic fuel delivery problem and listed the main pieces.
    I would look for a rebuilt throttle body, they will usually take your old one on a trade-in.
    Glad you found your problem.
  10. Skippy
    I'm going to call this out, just in case you're unaware. Aftermarket fuel pumps have a higher than normal failure rate. It's been my personal experience that about 1 in 10 go out relatively quickly, requiring a replacement. In fact, two of the last 6 I've done had to be replaced, one in less than a week (was bad from the get go), and the second within 12 months. I strongly recommend you put a fuel pressure tester on the rail and make sure you're getting what you expect.
    Skippy
