1995 Rear Bumper Replacement/Upgrade?
Discussion in 'Chevy Suburban Forum (GMC Yukon XL)' started by KirkW, May 27, 2010.
  1. KirkW
    KirkW Rockstar
    The rear bumper on my '95 Suburban is rusting out. I can get an OEM replacement, but I like the newer Suburban's that have the trailer wiring socket built-in to the bumper.
    (on my current bumper I removed one of the license plate lamps, enlarged the hole and mounted the RV7 socket there).
    Does anyone know if a newer rear bumper will bolt up to a '95 Surburban? Or am I stuck with stock/OEM?
  2. murdog94
    I would measure the distance between the frame rails, and mabey someone else on here would be kind enough to do the same. I have the same model truck as your suburban and have a 10K lb, rear bumper and the 7 pin is built in but i know that was installed in 1988 with the truck at the dealer.. That might be a way to go...
