1995 suburban 2500 sagging doors
Discussion in 'Chevy Suburban Forum (GMC Yukon XL)' started by kiaracer, Sep 24, 2013.
  1. kiaracer
    kiaracer New Member
    Hey I was wondering what's the easiest way to fix my two front doors they both droop the passenger door is worse then the driver door any info would be great
  2. rileyjr16
    Could be your door pins. Worst case is the hinges are actually bad. A body shop should be about 50$ to change them depending on which one. Or you could do it yourself but its a big p.i.t.a.
  3. Pikey
    there is a company (I don't know the name) that sells a spacer. You pick the door up, slide the spacer in and you are on your way. Personally, I would just replace the pins as stated above. It is not that bad of a job if you have help and can actually get the old pins out
  4. rg79
    rg79 New Member
    Hinge pin and bushing kit. Like Pikey stated, it's not too bad of a job with help.
  5. estrom
    estrom Rockstar
    Pin kits are about $7-$10 per door and there are youtube vids that show you how it's done. Not that bad. The spring is the only annoying factor in the process.
  6. kiaracer
    kiaracer New Member
    Thanks everyone I appreciate the help/info
