1996 5.7 running rough
Discussion in 'General Chevy & GM Tech Questions' started by 1996k1500, Apr 5, 2010.
  1. 1996k1500
    1996k1500 New Member
    i have a 1996 chevy k1500 5.7. i recently installed a comp camshaft since then my truck idles rough and has a sputter at initial throttle but smoothes out.it is throwing a muti missfire and throttle position senor low circuit code.what could be the cause of it?
  2. black98noma
    black98noma Rockstar
    sounds like a timing issue...
  3. vncj96
    X2 sounds like timing to me too.......
  4. ejohnson03
    ejohnson03 Epic Member 5+ Years 1000 Posts
    When setting your timing, be sure to disconnect the computer.
    On my '94 K1500, it was located behind the dash and underneath the glove box.
    I believe it is a brown or tan wire with a black stripe.
    Once it is disconnected, set the distributer timing at 0 degrees.
    Then after connecting the computer back up, the timing should readjust itself.
    Good luck...
  5. Loggerhead Mike
    with the wire still connected your comp will go into default mode
  6. 1996k1500
    i got a t.p.s. and that fixed the rough idle but i still has the sputter i will take a look at that tomorrow thanks for the input.
  7. murdog94
    Clean your I.A.C as well..... That can cause a sputter...
