1996 overhead (rear control) fan switch quit working???
Discussion in 'Chevy Suburban Forum (GMC Yukon XL)' started by estrom, May 16, 2013.
  1. estrom
    estrom Rockstar
    The overhead fan switch that controls the rear fan blower has quit working. Nothing blows in the rear on any of the settings - dead. I guess the 3 options are fuse, resistor, or blower motor. Anybody have any idea which one? There's lots of info. on the web about the front resistor which is located under the dash, but nothing on replacing the rear resistor. I assume it's located in the back with the motor? Thanks for any thoughts!
    - - - Updated - - -
    I guess I should add that I'm talking about the switch on the front overhead console, not the back switch above the 2nd row seat.
  2. Pikey
    I would start by checking the fuse, It should be in the panel on the drive side of the dash. Then, I would use a test light and see if you are getting power to and from the switch, check every position. Next, I would check the power at the fan, make sure it is getting to it. If not then I would track down the resistor which I would also assume is in the rear near the fan. I know that my 1995 silverado had issues with the connector for the front fan melting. Maybe it is something simple like that.
  3. estrom
    estrom Rockstar
    Thanks Pikey. I need to do some checking this weekend.
  4. estrom
    estrom Rockstar
    Follow up question...some quick checking revealed that the fuse labeled "blower" in the fuse box in the engine compartment was actually missing. I just purchased the vehicle, so I have no idea why they took it out. Anyway, I borrowed a 60 amp fuse from another slot, and the fan controls all work. There's some 50 amp and some 60 amp fuses in that line, so can someone who owns a '96 or similar suburban please look and tell me what amp fuse I need? I think it's the 6th one down from the top in the far right side column of fuses in the engine compartment fuse box. I bought a 60, but figured I would check first to see if someone could tell me what it's supposed to be. The owners manual labels it, but doesn't give amperage. Thanks!
  5. estrom
    estrom Rockstar
    I'm not an electrician - is it okay to use a 60 amp fuse in a 50 amp slot?
  6. Conlan Rose
    Temporarily if it is absolutely necessary yes, but you won't be protecting the circuit safely.
