1996 suburban 1500 turn signal issue
Discussion in 'Chevy Suburban Forum (GMC Yukon XL)' started by barryT, Nov 13, 2008.
  1. barryT
    barryT Member
    Well I am new here and I need a little help. About three days ago the turn signal flasher relay under the dash neer the floor board started clicking all the time. It stops some times but is on most of the time. I replaced the flasher relay and the problem still persists. When it is clicking the turn signals are not coming on. I did buy the turn signal/ cruisercontrol / wiper switch. I haven't installed it yet, but will this fix my problems? I forgot to mention my turn signals still function fine when activated. Just when the turn signals are not activated the relay is clicking away by itself.
  2. Zabob44
    Zabob44 New Member
    Maybe your getting back feed power from something else..have you looked at a diagram to see what else is fed off that circuit? Check power at the relay maybe your just getting partial voltage from somewhere else.
  3. dwill3015
    Welcome to the site!
  4. barryT
    barryT Member
    When the noise goes away and I touch the turn signal switch assembly I starts again.
  5. retired
    retired Rockstar 100 Posts
    It is possible for the combination switch to short out but try replacing the flasher.
  6. barryT
    barryT Member
    I did replace the flasher and there is no change. Napa doesnt except returns either. Well at least I have a spare right? :)
  7. retired
    Flashers are cheap anyway.
  8. Zabob44
    Zabob44 New Member
    sounds like a combination switch problem to me then
  9. JDF
    JDF New Member
    Hi Everyone, I'm a new member here, I have a 96 K1500 and 97 Subn. I have a similar flasher problem with my 96 K1500. The blinking stops when I use the brake pedal, and the turn signals work, but It constantly clicks while driving. I replaced the flasher unit and still persists I wonder if you (Barry) had any success with your similar problem. Thanks
  10. GaryL
    My Dad's 96 Silverado did the same thing. I endend up replacing the turn signal switch. You have to remove the air bag and steering wheel to get to it.
