For Sale 1997 Chevy 2500 4x4
Discussion in 'General Classifieds' started by agpride, Jan 10, 2012.
  1. agpride
    agpride New Member
    [h=1]1997 Chevy K2500 (Cheyenne), ¾ Ton, 4X4, Vortex 8cyl, 350ci-5.7L, 4-Spd. Automatic Transmission[/h] Specifications are as follows:
    [h=2] [/h] [h=2]Exterior – [/h] Heavy Duty Springs/Suspension
    Heavy Duty Transmission
    GVW Rating [8600 lbs.]
    Anti-Lock Braking System
    8-foot bed
    Regular Cab
    Pendaliner Bed Liner
    Grille Guard
    V-5 Rated Rear Bumper
    Amber Roof Lamps
    BF Goodrich All Terrain TA-KO Tires [LT245-75-16-E Load Range] Installed 5-18-10
    American Racing Baja Alloy Wheels [16x8]
    American Racing Center Caps [stainless steel]
    Hood and Window Protectors
    McGuard Locking Lug Nuts
    Bell Anti-Theft License Plate Cover
    Stant Locking Fuel Cap
    [h=2]Interior-[/h] Full Bench Seat
    Power Steering
    Tilt Wheel
    Locking Steering Wheel
    Cruise Control
    Electronic Shift [4 wheel drive]
    Air Conditioning
    Manual windows and door locks
    Reese Brake Control for Trailer
    Husky Liners [floor liners]
    Pioneer [DEHP 3600] am-fm-cd with remote, 6.5” Door Speakers, 4x6 Rear Speakers
    JVC 4-Channel Amplifier [KS-AX4550]
    Memphis 12” Sub-Woofer Truck Box
    Gun Rack
    [h=2]Parts Installed-[/h] Interstate Battery MTP-78 (NEW) [85 months / 1000CA – 800CCA] Installed 02-20-07
    Distributor Cap and Rotor (NEW) Installed 02-18-09
    K&N Air Filter (NEW)
    Ultra Premium Rotors (NEW) Installed 11-11-09 [Life Time Warranty]
    Semi-Metallic Ultra Brake Pads (NEW) Installed 11-11-09
    Replaced Manifold Gasket (NEW) Installed 1-23-09
    Front Hub Assemblies (NEW) Installed 11-11-09 [Life Time Warranty]
    Left and Right Heavy Duty Design Sway Bar Links (NEW) Installed 08-12-09
    Alternator (NEW) [Life Time Warranty] Installed 05-18-10
    KYB front and rear Shocks (NEW) [Life Time Warranty] Installed 08-26-10
    KYB Steering Stabilizer (NEW) Installed 08-26-10
    GMC Tailgate Latches and Strikers (NEW) Installed 08-26-10
    GMC Tailgate Hinges (NEW) Installed 03-29-07
    Fuel Tank (NEW) [Life Time Warranty] Installed 08-26-10
    Fuel Filler Neck (NEW) Installed 11-11-09
    Fuel Pump and Hanger with Sender (NEW) Installed 05-18-07
    Soundmaster Muffler (NEW) [Life Time Warranty] Installed 08-26-10
    Classic Tube Fuel Lines Stainless Steel (NEW) Installed 11-11-09
    Copper Coated Emission Vent Line (NEW) Installed 11-11-09
    Ignition Lock Cylinder (NEW) Installed 07-06-10
    Windshield Wiper Motor (NEW) 05-08-08
    Severe Duty with Heavy Duty Tow Package Fan Clutch (NEW) Installed 07-11-07
    Thermostat (NEW) Installed 07-11-07
    Serpentine Belt, Auto Tensioner, and Idler Pulley (NEW) Installed 12-01-11
    Pitman Arm (NEW) Installed 09-26-05
    Rear Left Wheel Cylinder and Brake Cable (NEW) Installed 12-13-07
    Steering Shock and Ignition Switch (NEW) Installed 06-04-07
    GMC Parking Brake Control Assembly (NEW) & GMC Parking Brake Switch (NEW) Installed 02-04-11
    Rear Right & Rear Left Premium Emergency Brake Cable (NEW) Installed 06-09-11
    GMC Brake Cable Equalizer (NEW) Installed 06-09-11
    Spark Plugs and Spark Plug Wires (NEW) Installed 12-01-11
    [h=3][/h] [h=3]Fluids Being Used-[/h] Fuel – 87 or 93 Octane
    Pennzoil Motor Oil [5w30 High Mileage]
    Toyota Red Coolant
    Dexron III Transmission and Transfer Case Fluid
    GMC 80w90 GL-5 Gear Oil with Friction Modifier
    GMC DOT-3 Brake Fluid
    GMC Power Steering Fluid
    ·Complete Power Steering Flush and Fuel Induction Clean Up [Performed on 11-07-03]
    ·Flushed Transmission Fluid and Replaced Gasket [every 50,000 miles]
    ·Changed Transfer Case Fluid [every 30,000 miles]
    ·Changed Front and Rear Axle Fluid [every 30,000 miles]
    ·Flushed and Replaced Coolant [every 30,000 miles]
    ·Changed Oil and Oil Filter with AC Delco Filter [every 3,000 miles]
    ·Changed Fuel Filter with WIX Filter [every 15,000 miles]
    ·Changed Power Steering Fluid at 103,380 miles
    [h=3]Additional Information-[/h] Current Mileage: 165,000
    Inspection & Emissions – Expires September 2012
    A Certified and Professional Mechanic did ALL work.
    Have ALL invoices of parts and work done, and original OEM Build Sheet to give.
    [h=3]Price-[/h] $6,000.00 – OR BEST OFFER!
    Cash in hand Only
    [h=3]Contact Information-[/h] Aaron
    Pittsburgh, PA
    (724) 265-8495
    [h=4]Pictures can be found at –[/h]
  2. summithighrise09
    summithighrise09 New Member
    Damn...this truck is clean!!!! I bet this workhouse sucks up the gas though. Good Looking Truck!!! GLWS
