1997 Chevy Vortec Distributor - Broken Screw Flange
Discussion in 'GM Powertrain' started by 4wd-burban, Sep 9, 2009.
  1. 4wd-burban
    4wd-burban Member
    Performed a tune-up on my 97 Suburban 350 Vortec and everything was going great until I went to tighten the front screw for the distributor cap. It was tightening fine and just starting to get snug, then flange/tab that the screw goes into snapped in half/off. Unless someone can provide a workaround it appears I need to replace the entire distributor correct?
    If so are there any techs that can tell me what the factory states is the hours necessary to get the job so I can get an idea of price? Also, any recommendation for replacement distributors?
    Thank you for your time.
  2. Jimmiee
    Yes you need a new distributor. Summit racing sells a house brand that is pretty good and reasonably priced. The labor should be about an hour to an hour and a half I would guess. I don't have a labor guide so that's just a ball park estimate.
  3. 4wd-burban
    4wd-burban Member
    Thanks for the response, forgot to respond that the distributor was replaced. With my work schedule just took it into the mechanic since he is reasonable.
