1998 GMC K1500 Suburban: New Here - questions on upcoming projects
Discussion in 'Chevy Suburban Forum (GMC Yukon XL)' started by TamiLyhne, May 8, 2017.
  1. Cowboytrukr
    Cowboytrukr Active Member 100 Posts
    Wipers are a solder joint problem.
    The connector on the wiper control module under the hood is notorious for failure. If you'd like to take it on, it's really not that difficult. You unplug it and remove the control module from the housing. Most of the time the fix is to simply reapply some heat to the solder joints on the main connector. Make sure your soldering iron is very hot to begin with and then touch each pin. As soon as you see the solder melt, you're ready to move to the next pin.
    It wouldn't hurt to have a coil of rosin core solder and some flux paste handy in case you need to doctor any of the joints with a little more metal. The flux is needed to clean impurities from the tip of the iron. You must only use rosin core for electronics. There is acid core solder on the market, but that is only used for copper pipe fittings. One other item to have by your side is a small damp sponge. The sponge is useful to wipe off excess solde from the tip of the iron.
    thegawd likes this.
  2. TamiLyhne
    TamiLyhne New Member GMTC Chick
    So don't start with the motors?
  3. TamiLyhne
    is it unrealistic to just buy a new connector? or a whole new control module? Soldering electronic components is not something i'm comfortable doing myself.
  4. Cowboytrukr
    The connector on the module is the problem. You could purchase a new one.
    It's really not that scary. All you do is touch the hot iron to each connector pin on the board on the side where they poke down through the board. Hold it on until the solder melts and then take it off. You really can't hurt it. It's only the few large pins for the connector. All you're doing is reseating the pins.
  5. xPosTech
    xPosTech Epic Member 5+ Years 1000 Posts
    Find the neighborhood Nerd. He/she can probably solder it for you.
    Ted
    thegawd, RayVoy and Cowboytrukr like this.
