1999 Suburban AC Wierdness!
Discussion in 'Chevy Suburban Forum (GMC Yukon XL)' started by BigRoy903, Jun 20, 2009.
  1. BigRoy903
    BigRoy903 New Member
    The rear AC blows fine and is cold, but the front AC flow is low and is not all that cold. Both units obviously run off the same compressor and other under-the-hood components, but do they use the same evaporator, etc.? Given that I live on dirt roads where dust is high, is there a filter that I should clean or is the evaporator clogged? Perhaps it is even a "flapper" issue between inside/outside air.
    I'm lost, where should I begin?
  2. vncj96
    I wish i knew exactly, I am having the same problem. When I get my truck back this will be my next project, I am going to start with the A/C dye you can put in to check for any leaks
  3. unplugged
    Check out this info at justanswer.com: http://www.justanswer.com/questions/tkaf-97-chevy-suburban-frOnt-ac-not
    Really sounds like you were looking for a diy answer. Personally I've found AC work to be expensive. And even more expensive if I try to fix it myself first. :glasses:
    There are guys on this forum who are AC gurus so stand by for more info.
