1999 suburban daytime running lights question
Discussion in 'Chevy Suburban Forum (GMC Yukon XL)' started by ochs99, Mar 9, 2010.
  1. ochs99
    ochs99 New Member
    I have a 99 suburban K1500 5.7, and am looking for some help with my daytime running lights. I went out the other day and upon turning on the truck noticed no auto daytime running lights. I have checked the fuse box on the side of the dash, the box under the hood and nothing seems to be blown. I have replaced the headlight relay under the dash with no results.
    If I manually turn the headlights on I have high beams, but no low beams. I have checked the actual bulbs on the low beams and they are fine.
    I was told that it could be the daytime running light module, and that it was located under the dash to the right of the steering column. I have ordered the part, looks like a oversized computer chip(which I guess thats what it is), but have yet to replace it
    Any advice on replaceing the part, not even real sure how to go about it. Am I even looking in the right direction to solve this problem?
    Any advice/help would be great.
    Thanks in advance!
  2. Joeairforce
    The daytime running lights may just come on when it's in Drive..... I know that's how they worked on my '04 I had...
  3. ochs99
    ochs99 New Member
    They always came on upon starting the truck, which leads me to believe it is a sensor or some such thing.
  4. Joeairforce
    That's right......... I think you're on the right track with the module.... I think it should just unplug and plug in....
  5. unplugged
    Module is $50. Maybe someone will chime in with way to test/troubleshoot the module.
    [​IMG]
  6. ochs99
    ochs99 New Member
    thats the part I got, and I think it should just be a simple plug in fix. just have to figure out how to get the unit out from under the dash enough to do the replacement.
  7. cyclrcr
    cyclrcr New Member
    I have the same problem with my '99, but my lights do come on when I turn them on.
    Thanks for helping ochs99... now I will see where I can get that part cheap and fix mine
  8. lexisdad1201
    lexisdad1201 New Member
    Any update on this? I have the same issue but the wiring diagram points to either the relay or the turn stalk switch. Just curious.
  9. milkweed79
    milkweed79 New Member
    Anytime you have a function that is sla
    slave to another and is not working properly on its primary function start with fuses. DRL fuse should be #15 or 17. Fuse panel should always be the start of troubleshooting. Never inspect fuses visually, always use a test light. There are nodes in the fuses for such maintenance inspections. 9 times out of 10 sudden car problems with no indication from the vehicle that it is beginning to experience issues is usually the result of a fuse or accessory relay defecting or faulting.
  10. Billy D
    Billy D Rockstar
    I had this, a wire in the column came out of the connector, I soldered it back in and did away with the daytime lights, just switch them on and off. At least that is what I remember since it was several years ago now.
