1999 Suburban Tune Up
Discussion in 'General Chevy & GM Tech Questions' started by coloradosuburban, Feb 17, 2010.
  1. coloradosuburban
    coloradosuburban New Member
    What are peoples recomendations for type/brand of items for a tune up?
    spark plugs
    Is the $70 Bosch wire worth it or are the $25 Mastercraft wires okay, etc?
  2. Silverado Junkie
    Silverado Junkie Rockstar 4 Years 500 Posts
    Ive always been a Bosch man. I really like the the bosch platinum 4 plugs and bosch plug wires. Id also change the air filter and fuel filter. And id go ahead and change the oil while your at it because you cant change it too much. I was told by an old mechanic many years ago that "oil is the cheapest insurance they sell." So i stick to that.
  3. vncj96
    I will tell you this and alot of others will too. The vortec motors can lose some by switching to a different spark plug other then the OEM. I can tell you when I bought mine it had the Bosch platinum in it and when i changed them out back to the OEM ac/delco plugs i got back 1.5 MPG and I still have those same plugs for 3 years now and no lose in MPG.
  4. Uncle Ed
    Uncle Ed New Member
    Vortec motors run very well on OEM plugs. Get iridium if you are not fouling plugs and then you can forget about them for awhile.
    NGK, reported to be the MFG of the oem plugs is another good choice.
    Depending on your motor; your plug gap should be .40, as revised by GM, instead of the .60 shown in your owners manual.
    x3.....On Going with A/C Delco Plugs & Wires.
  6. jamin121884
    jamin121884 New Member
    Bosch +4 plugs are not only redundant, overly-hyped, and less effective, but also expensive. Working in a part house for 8 years may not make me an expert by any means, and ASE P2 certification doesn't mean mud anymore, but I have never had more complaints about a plug, Champions included, then Bosch plugs. 'Car and Driver' had a piece a year or so back about plugs that proved, in a 5.7 engine much like the one in your Suburban, that NGK Platiums not only give you the best preformance but also cost less then most designer plugs on the market. Do I personaly believe this, yes, but I have had good results from Autolite as well, which many consider a poor, cheap plug. Switching to an after market filter (I'm not a K&N fan, but damn it works well on this motor) will add some mileage per gallon. Never buy a chip off of eBay. NEVER. If you want to "chip out" your 5.7 the only way to go is to get it done right, which will cost some major money. Your looking five, six hundred big ones. If your looking for a basic, low maintance, low cost "upgrade" for your ride, get an after market air filter, NGK platium plugs, decent wires (Belden, found at Napa is a decent low cost choice, or whatever aftermarket company your buddies 'won't do without') a new fuel filter, cap rotor, and just take care to follow normal maintenece. It's pretty easy.
