2000 3500hd blowing black smoke????
Discussion in 'GM Diesel & DuraMax' started by bigdaddy77084, Oct 30, 2010.
  1. bigdaddy77084
    bigdaddy77084 Epic Member 5+ Years 500 Posts
    I drive a 2000 3500hd at work & pulling a load it has no power and blows black smoke bad. changed air,fuel,oil filters.. The bosses mechanic is a jerk he is lost.. I think its the turbo or the air pump?????any help????
  2. Sam_A
    Sam_A Rockstar 100 Posts
    If it is a diesel, have you checked the injectors?
  3. ntbush83
    x2 on injectors!
  4. bigdaddy77084
    His mechanic is lost. the service engine light is on. Its says its turbo pressure??? It goes down the road great with no load behind it.Starts right up,uses no oil. Yes it a diesel.
  5. 54chev3100
    54chev3100 New Member
    I would have to agree on injectors, but first is the truck equipped with egr, because if the egr valve is hung paritally open due to soot accumulation then it would cause excessive black smoke and low boost pressure. And also check for any boost leaks in the pipes or intercooler.
  6. Joeairforce
    Check the vacuum pump out and check the waste-gate solenoid for operation and all the vac lines....
