2000" GMC Electrical Problem
Discussion in 'General Chevy & GM Tech Questions' started by AK Badger, Dec 11, 2013.
  1. AK Badger
    AK Badger New Member
    I have a 2000 GMC sierra that I use as plow. It started great 3 weeks ago and now with the threat of snow it seems that I have now power what so ever to anything in the truck. I have two batteries, new last year. The one battery took a full charge but the second one does not take charge or respond to charger. Any ideas?
  2. 99'HEARTBEAT
    ****THREAD MOVED****
    To The
    GENERAL CHEVY/GM TECH QUESTION SECTION
  3. dpeter
    First thing I would do is take the battery that won't charge back for replacement, hopefully under warranty. Second would be to recheck all battery connections and cable condition. Then start looking for shorts or loads that are staying on.
  4. RayVoy
    X2 ^^^^. Do you have any sort of battery isolation, or the two batteries just connected in parallel? And, where do you connect the charger, directly to the battery terminals, or at a common point?
  5. Albert
    Albert New Member
    Isolate the rotten one and charge it alone and see it charges or not. Go for replacement if its finished! Also check for any short circuits and wiring issues. It also looks like may be you are connecting the charger in the wrong way!
  6. dpeter
    Looking over a Haynes electric diagram for charging and starting and do not see a dual battery set up. Check your ignition fuse as that will kill dash and prevent cranking. Do exterior lights work?
