2000 Jimmy, misfire question but not the typical ones
Discussion in 'Chevy Blazer Forum (GMC Jimmy)' started by Hardin, Mar 13, 2014.
  1. Hardin
    Hardin New Member
    Good afternoon everyone, thanks ahead of time for any responses.
    I picked up a 2000 Jimmy the other day with what I was told needed a new spider and intake gaskets... I got it started up but now I have the dreaded P0300!!!! I have done all of the following...
    New spider
    intake gaskets
    ac Delco dizzy, rotor and cap
    new plugs
    wires,
    clean egr
    clean mac
    checked for vacuum
    checked fuel pressure... holding 60psi.
    now... I have a wet number 1 plug and backfiring..
    The only thing I haven't done, and I'm sure I I'll be told to, is check compression. So here is my question
    Lets say I check compression and find a cylinder or two that fail, what then? Assuming I'd have to pull the valve covers and check (wish I would have when I changed intake gaskets!!!) what will I be looking for? I've heard a sticking valve could also cause my problems, is this true?
    Thank you,
    Jeremy
  2. edsmagichands
    edsmagichands Member 2 Years 100 Posts
    What engine? do the compression test and check your timing first. let us know.
