2000 jimmy po146
Discussion in 'General Chevy & GM Tech Questions' started by harleybuda, Oct 16, 2011.
  1. harleybuda
    harleybuda New Member
    i am getting a po146 code on my wifes jimmy which no activity detected bank 1 sensor 3 my problem is i do not have a sensor 3 ??? i have 1 on each pipe off the manifolds and 1 down stream past the cat so the most i believe i could have would be bank 1 sensor 2 i am stumped and i have replaced the o2 sensor downstream
  2. 99'HEARTBEAT
    The 02 Sensor Downstream, after the Cat......is the number 3 Sensor and for a P0146,
    Potential causes of an Trouble code P0146 include:
    • Bad Bank 1, Position 3, 02 Sensor
    • Wiring problem, melted harness, broken connectors, etc.
    • Bad PCM
  3. murdog94
    That is it. most likely a broken wire somewhere
  4. harleybuda
    would you know which wire or wires it could be and could i just run a new one i have traced them back and they don't seem to be damaged and i have not been able to locate a diagram that shows the o2 sensor down stream i have tested with a multi meter and everything tests ok
