2000 silverado brakes
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by gary f, Feb 13, 2012.
  1. gary f
    gary f New Member
    hi , i replaced alllines on my 2000 silverado and no i am having a hard time trying to bleed the lines,
    it seems ok lots of pedal then i drive for a day or two and i get the soft pedal and hard to stop.
    is there something out of the norm that has to be done
  2. Red Z71 Max
    Possibly a bad Master Cylinder or your caliper lines are bad and buldging under pressure.
  3. gary f
    gary f New Member
    thanks, how do you check the master cylinder
  4. murdog94
    if you poped the bleeder for all of the brakes, and got air in then you will need it to go to the dealer (this is usually the only place that has the correct power bleeder for the GM trucks) Though your local shop may be able to do it. the ABS manifolds cannot be bled with out that.
