2000 Sub. 1500 LT Alternator Issues?
Discussion in 'Audio, Video & Gadget Tech' started by buckmiestr, Jul 14, 2009.
  1. buckmiestr
    buckmiestr New Member
    My in dash voltage guage ocillates between 13 and 15 volts. This ocillation is very rapid approx. 1 time per second. When driving at night, the headlight, and dash light flicker at the same rate as the volt guage. The rate of the ocillation does not seem to very with engine speed. The ocillation sometimes goes away completely, and somtime lessens to only a 1/2 volt of fluctuation. I suspect the alternator is more than likely at fault. I have not have any issues with the battery not charging or failing to start. Has anyone seen this type of behavior? Thank you in advance if you are able to help.
  2. Z71_guy
    the voltage regulator in the alternator could be going out, may want to have it load tested at a shop
  3. 1_low_rider
    1_low_rider Rockstar 100 Posts
    i 2nd that
