2001 factory alarm help
Discussion in 'General Chevy & GM Tech Questions' started by ALLKUSTOM, Jul 18, 2009.
    ALLKUSTOM New Member
    I replaced my battery in my 2001 chevy silverado and now the keyless entry / alarm doesnt work. Is there a way to reset the alarm or what do i have to do? Thanks
  2. 2ToNe04
    google is a great rescource :)
    Here is the process as per GM. Remember that all your key fobs must be programmed at the same time since once you begin this process the truck erases all previous fobs.
    1. Close all the vehicle doors.
    2. Insert the ignition key into the ignition lock cylinder.
    3. Press and hold the door unlock switch.
    4. While holding the door lock switch in the unlock position, cycle the ignition ON, OFF, ON, OFF.
    5. Release the door unlock switch. The doors will lock and unlock to confirm the program mode.
    6. Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of approximately 15 seconds, the doors will lock and unlock to confirm the programming of that transmitter.
    7. Repeat the previous step to program up to 4 transmitters.
    8. Turn the ignition switch to the RUN position in order to exit the keyless entry transmitter programming mode.
    9. Operate the transmitter functions in order to verify correct system operation
  3. bill190
    bill190 Rockstar 100 Posts
    Might also be in the owner's manual under "Theft Deterrent".
