2001 GMC 6.0L Rough Idle and Almost closed throttle Miss No Codes
Discussion in 'GM Powertrain' started by Mr Wizard, Jul 24, 2010.
  1. Mr Wizard
    Mr Wizard New Member
    I just purchased a 2001 GMC 2500 hd with only 20,000 miles on it. Looks and drives just like a new truck. At idle it seems to run smooth and then stumble abit, Then it returns moments later??? How it corrects itself is a mystery. Also after the truck shifts out and low rpm only slight throttle it seems to have an engine miss more like a lean stumbling feeling. All other positions runs great! I have replaced the gas filter, air filter, spark plugs, wires and cleaned the mass airflow sensor. No difference???? Also no codes?? Any ideas would be very much appreciated. Thanks!!
  2. L0sts0ul
    L0sts0ul Rockstar 100 Posts
    seafoam, tune up then see what happens
  3. Mr Wizard
    Tune up did not change a thing..... How does seafoam work? Any other ideas??
  4. L0sts0ul
  5. murdog94
    Pull the IAC (idle air control valve) out of the Throttle body and clean it out and the pathway for it out. Sounds like a classical symptom of gummed a up IAC.
    I also would for sure do a seafoam treatment. But when you put it into the motor let it sit for an hour or so (they reccomend 15min or something) after you have done that take it for a drive and you should have all the carbon blown out of hte top end of the motor.
