2001 Suburban 4wd issue
Discussion in 'Chevy Suburban Forum (GMC Yukon XL)' started by cbe295, Jan 20, 2013.
  1. cbe295
    cbe295 New Member
    I have an 01 suburban 1500 4x4. The 4 wheel drive is push button. It's not working. I push the 4 hi or 4 low or auto and the lights switch to whatever button I push. Also, I can hear the actuator working. I have no idea what it could be. I heard if your abs light is on it won't engage so I got that problem out of the way and it's still not working. Any ideas? Thanks.
  2. Pikey
    check the front actuator. Unscrew it from the axle and put it in 4x4. See if the piston moves out.
  3. cbe295
    cbe295 New Member
    I tried that. The piston moves out. Would the 4wd not work if there wasn't any fluid in the transfer case?
  4. Pikey
    It may or may not work. It may work for a short time. If yours is empty that may be why it is stuck in 4x4
  5. cbe295
    cbe295 New Member
    It's full of fluid. It's not engaging into 4x4. It's stuck in 2wd
  6. Kady
    Maybe its the switch on the dash?>?
  7. cbe295
    cbe295 New Member
    As soon as I get money I will buy one and put it in. I got told from a guy that works at advance auto that it could be the switch or the transfer case motor.
  8. cbe295
    cbe295 New Member
    So i put a new switch in and the 4wd still isnt working. Me and a buddy jacked the truck up and hit the 4wd button and could still spin the tires so the front end wasnt locking in.
  9. cbe295
    cbe295 New Member
    I had to rebuild the front diff. The washer type thing in there got pushed around and messed eveything up. Thanks for the help though.
