2001 VSS wearing out in minutes
Discussion in 'GM Powertrain' started by mrrustication, Aug 24, 2011.
  1. mrrustication
    mrrustication New Member
    To everyone reading this thanks for your time. I have a 2001 silverado Z-71 and recently stumbled upon a huge problem. Occasionaly on the interstate my speedometer cut out and the truck downshifted, speedometer would kick back on rather quickly and transmission would re adjust. This happened 2 or 3 times. Less then a week later the speedo began to cut in and out and the transmission would shift according the speedometers reading. After some quick help from google i determined it was the vss(s). I replaced the 2 on the rear of the transfer case and the one on the front as well. The two rear ones had a groove worn into them. Within the first few minutes of my testdrive the same problem began to occur again. I nursed the truck back home, pulled the sensors and the new ones (2 rear) already had the same "groove" worn into them. Any suggestions greatly appreciated, it looks to me like something in the transfer case which is beyond my mechanical ability.
  2. Crawdaddy
    Crawdaddy has no brakes Staff Member 5+ Years 1000 Posts Platinum Contributor
    it sounds like the tone ring that drives the VSS is loose or somehow out of tolerance and allowed to contact the vss. Time to start pulling stuff apart and find out why you're having physical contact in a place where there's not supposed to be any contact.
  3. silveradotrailblazer
    Welcome to the club. X2 what Crawdaddy said.
  4. Crawdaddy
    To clarify, the tone ring should not touch the VSS, but it should be VERY close to it. I don't know the spacing off-hand, but it's less than 1/4".
