2002 Silverado 3500 Instrument Cluster Problem
Discussion in 'General Chevy & GM Tech Questions' started by davmaj2, Dec 15, 2009.
  1. davmaj2
    davmaj2 New Member
    I am having problems with my '02 Silverado 3500 instrument cluster.
    It started yesterday.
    I know it is not the cluster because I tried it in another truck and it worked just fine.
    I have tried a to scan the codes, but I cannot get it to communicate with the truck.
    All fuses and relays are good.
    This is what it is doing:
    Lights ON:
    ABS
    AirBag
    Security
    Battery
    Low Fuel
    Gauges Don't Work:
    Fuel
    Temp
    Trans Temp
    Automatic headlights do not work.
    Tow/Haul mode does not work.
    High Beam Indicator does not Work.
    Gear Indicator does not work.
  2. BIGDAUTOSALVAGE
    BIGDAUTOSALVAGE New Member
    Did you ever find a fix to this problem? Having the exact same issues with a 2000 Silverado.
    Thanks, DW
  3. BIGDAUTOSALVAGE
    We found our problem. It was actually in the ABS pump assembly. We unplugged the module on the pump assembly and all the warning lights went off and everything went back to working properly.
