2002 silverado brake and right. blinker problems(HELP)! ASAP
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by famousxking, Nov 28, 2011.
  1. famousxking
    famousxking New Member
    So I had this problem before and it was fixed by the dealer and now I'm having the problems again and I'm about to go get the inspection sticker for the truck so I need help asap.
    Whenever I press the brakes the right blinker will light up but in a dim manner and none of the brakes will light up and when I need to use the right blinker and need to slow down at the same time the blinker blinks really fast and during the night it will just completely stop. I have no idea what it is and I need a permanent fix
  2. Pikey
    I had a similar issue with my 02. The wiring harness had become corroded. My plug was located on the rear cross member of the frame. I pulled it apart and cleaned it with contact cleaner. When I reassembled it I put some white grease on the plug to help prevent future corrosion. I did notice that the clip that held the plug together was broken, so I actually used some zip ties and held it together.
