2002 Suburban Gear Indicator/Odom
Discussion in 'Audio, Video & Gadget Tech' started by sagodbehere, Sep 26, 2009.
  1. sagodbehere
    sagodbehere New Member
    I have a problem with the Gear Indicator/Odom. It will not light up. Over the past month it would sometimes light up after starting and some time it would not. It currently will not light up. I have checked and changed the IGN 0 fuse in the interior fuse box. This did not help. All other indicators appear to be lighting up. Any help would be appreciated.
  2. vncj96
    You are probably gonna have to go to the dealership, as alot of stuff that goes on with instrument clusters isnt a fix the problem its replace the cluster, and only the dealership can do it as the mileage gets set at the factory.
  3. jpgoodnu
    jpgoodnu New Member
    Just found this post,Try Charlie at Florida Speedometer(954-818-8188) ha can fix the bad solder joints that cause this problem and he can program the mileage if neccessary,he's done several for myself and friends.
