2003 Silverado Extended Cab
Discussion in 'Member Introductions' started by ab2650, Jan 24, 2013.
  1. ab2650
    ab2650 New Member
    Hello everyone. Glad to be a new member here. I bought a used '03 Silverado (5.3L Z71, LS, Extended Cab) with 105K miles on it. There are a number of things I have either fixed or still need to fix, so I'm sure I'll get some good information on the forums here. The "best" fix so far turned out to be a busted speedometer that the dealer quoted me $600 for a rebuilt cluster; Doing a little research I found that soldering in new stepper motors was cheap and I found a guy (on ebay) to do it for less than $50 (since I can't solder worth anything). I also replaced a leaky axle shaft seal, A/C belt, and parking brake switch and cable. Installed an aftermarket headunit with handsfree and harness that retains the door chime. Not bad for a truck that I've only had 2 weeks!
    The two things vexing me now are a possible leaky door (the floor mats were soaked after a big rain), and troubles programming a second keyless entry remote. I'll head over to the right forums and see what I can find out.
    So thanks for having me, forums!
    -AB
  2. Curky
    Curky Epic Member 5+ Years 1000 Posts
    Welcome to the club. Glad to have you :great:
  3. donyms
    Welcome to the club, it's good to have you here.:glasses:
  4. SurrealOne
    Welcome! :great:
  5. Pikey
    Welcome to GMTC! As far as you leak goes, I would take a look under the cowl where the windshield wipers mount. Pull the wipers and take out the screws holding the plastic grill down. Look for cracks in the "putty" that is used between the cab and front end.
  6. AMac
    AMac Rockstar 3 Years GMTC Chick 500 Posts ROTM Winner
    Welcome to the club and good luck with your leak issue and nice job on saving money on fixing the speedometer.
  7. silverhobey
    welcome aboard, you busy little beaver---i'm sure you will enjoy it here...Brian
  8. TRPLXL2
    Welcome to the site!!!
    Once upon a time I bought a spare gauge cluster for my 05' Silverado, and I bought all the parts to do it but chickened out when I saw all the tiny little parts inside.......
