2004 Silverado AC only blows on high
Discussion in 'GM Electrical Tech' started by TELORVEHC, Mar 14, 2010.
    When I turn on the AC or the heat in my truck, it only works if I put the dial on the '5' setting out of '0-5'. I think its a bad switch or something, but I don't know how I would go about repairing it :confused:
  2. vncj96
    Its not the switch it the blower motor resistor, they tend to go out. easy fix and only 20 bucks or so for a new resistor.
  3. MonteCristo
    MonteCristo New Member
    I definitely am having the same problem in my 2004 silverado 1500 4x4. The heat/ac fan has gradually stopped working on the 1-4 levels and now only operates on full blast #5. I need to fix it soon.
    Where is the blower motor resister located? I do not have a repair manual for this vehicle yet.
    Its located in the passenger footwell underneath the glovebox. 2 screws hold the resistor in place hen unplug the harness from the unit.
  5. vncj96
    when you look in the footwell the actual blower motor is behind the plastic shield that has a round shape to it. there will be a twisted bundle of wires coming off it, they lead to the resistor, the resistor is actually bigger then you would think and it looks like those childs play deals that you slide the beads over, up down and coiled, every doctors/dentist office seems to have it (best way I know to describe it). Unclip the wire brackets and two screws and its out.
  6. 03 Black Sunshine
    03 Black Sunshine Rockstar 100 Posts
    mine doesnt work on the "5" setting. My wifes TB quit working last summer, and I replaced it. Her TB is an 02 and it is a really easy fix. 15 -20 minutes and it is done.
  7. SCAIR001
    SCAIR001 New Member
    The late model resistors are solid state. Module more than likley bad and they often burn the connector
  8. MonteCristo
    Thanks for the help guys :great:. I was able to locate my resister easily thanks to y'all. The card itself had visible burn damage on it. I did have some trouble getting the right replacement from the parts store. One store only had a model for vehicles without the "floor console", so the part wasn't even mountable.
    Two part stores later, I found the right one and got it mounted in and it completely fixed my problem. Now I have functioning AC/Heat!!:party:
