2004 Silverado vibration
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by Chris Platte, Jan 23, 2012.
  1. Chris Platte
    Chris Platte New Member
    Hey
    I have a 2004 silverado and it just started viberating. It only does it when on the throttle between 25 and 45 mph. any idea would be great.
    Thanks
  2. mfleetwood
    Hi Chris - Did you recently hit a curb, change tires (or one of them), do front end work, etc.? Any additional background/info would be helpful.
  3. Chris Platte
    all i have done is replace the brakes on the rear. it strarted during a hunting trip with lots of mud but I washed it for over an hour thinking there was some mud stuck somewhere but it didnt make any differnce.
  4. mfleetwood
    That's odd. Even though it doesn't sound like you did anything that would have caused the alignment change, my gut still says to have the alignment checked anyway. You could have hit a rock or root that was buried in the mud. However, let's see what others say, as someone may have the answer for sure.
  5. Chris Platte
    yea i probably should have the alingment checked thanks for the quick response!
  6. luvit4it
    luvit4it New Member
    try checking any mud build up on the inside of rims that could throw the wheel balance off
  7. chevybulldog6
    chevybulldog6 Rockstar ROTM Winner 100 Posts
    This happens to me occasionally after wheeling. I end up getting mud on the inside of the wheels and in the front rotor vents. I just take the front tires off and clean the rims and spray out the rotor vents, problem solved. I hope this helps.
