2004 yukon xl denali 6.0L P0420 code
Discussion in 'GM Powertrain' started by Pikey, Jun 5, 2013.
  1. Pikey
    My cousin contacted me and asked me about a p0420 code that he is getting on his truck. I read around and found that it could be a bad cat, a bad O2 sensor, a bad engine temp sensor, or a bad fuel pump. He tested the pump today and found the pressure to be 60psi while running, 52 psi when shut off, 44 psi 5 minutes after shut off, and 40 psi 10 minutes after shutoff. So, my question is, does this indicate a bad fuel regulator? Would a bad regulator cause the truck to run lean and therefor throw the code? or is basically a bad cat with that code? I also have a freeze frame from his scan tool that he sent me. Any ideas guys? He cleared the code and it came back a week later.
    DTC that caused the freeze frame PO420
    Throttle position 14.9%
    Engine RPM 546
    Load value 2.3%
    Air flow rate 6.89 GR/SEC
    MAP sensor 39KPA
    Coolant temp 201 F
    Short term fuel trim 1 3.1%
    Long term fuel trim 1 -4.6%
    Short term fuel trim 2 0.7%
    Long term fuel trim2 -4.9%
    Short term fuel trim 3 40.6%
    Long term fuel trim 3 99.2%
    Long term fuel trim 4 83.5%
    Short term fuel trim 4 65.6%
    Vehicle speed 0MPH
    Fuel system 1 Open 1
    Fuel system 2 Open 1
    I/M Monitors
    Misfire Mon ok
    Fuel sys mon ok
    Comp comp ok
    Catalyst mon oj
    HTD catalyst n/a
    EVAP sys mon inc
    SEC air sys n/a
    a/c refrig mon n/a
    oxy sensor mon ok
    oxy sen HTR ok
    EGR system mon n/a
